Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol
Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here!
Old 03-23-2007, 07:47 AM
Bobc007 is on a distinguished road
Restart of integrex eia program with dual turrets
We've just acquired an Integrex 100-IIIst machine with a lower turret that we are programming in eia. We haven't figured out how to do a restart yet. Normally we would call up the eia program as the current work no., curser down to where we'd like to start in the program and hit the "Restart2 nonmodal" button. Then start running.
Our experience so far has been that the machine gets confused and both turrets start running at the same time.
Anyone using eia programs that has a procedure for successfully restarting?
Old 03-25-2007, 07:14 PM
out2thow is on a distinguished road
What control is on that Integrex, I had heard that there is a bug in the Matrix controls for EIA restarting on Integrex Mark IV machines......
Old 03-26-2007, 08:03 AM
This has the MTPro control.
Old 04-01-2007, 07:43 PM
have you tried using the restart on the main softkey menu???
make sure you restart at a tool index for a safe start.
when you hit restart, hit enter again to write the same program you are using for the Sub-Program (first line)
then enter the N number for sequence number
Block number will = 1 to start on that N# line (2 will be the line after N#, 3 will be the second and so on)
enter 1 for the repeat # times
and away you go! give it a try
-S
Mazak Integrex 200 III St ISO/EIA maramb Mazak, Mitsubishi, Mazatrol 19 11-28-2007 02:41 PM
Controller Restart problem! VB IT General Electronics Discussion 0 02-25-2007 02:48 AM
Integrex IV help Demon440 Mazak, Mitsubishi, Mazatrol 8 02-19-2007 01:21 PM
integrex 50 YB ISO Programming Batman G-Code Programing 3 12-12-2006 05:47 PM
haas floppy dnc restart bytecolor Haas Mills 6 10-19-2006 07:31 AM
