Results 1 to 2 of 2
Thread: Eia Tool Hieght Offset On Nexus 640
    Apr 2005
    canada
    Is There An Easy Way To Set Tool Height On A Mazak 410a Mill
    When Using A G Code Program. I Am Used To Just Putting The
    Tool In The Spindle And Touching The Tool Off The Top Of
    The Work Piece Then Setting The Tool Height Based On The
    Machines Distance From Home Position In Z Axis (always Is A
    Negitive Number). This Machine Does Not Work This Way??..
    Mar 2005
    Silicon Valley, CA
    Well, ... it will but I don't know why you'd want to. Whats not working for you? Mazaks (as well as many machine tools nowadays) are on the concept that most people are using positve offsetting and not the old style minus setting. Do you have the tool measure unit on the machine? It will already be set for positive offsetting. Positive offsetting is based upon the spindle gage line being at the workface zero, then offsettin the tool length in positive. This also has many other benefits.....
    But, I would think you can still set all your tools that way (on the part). Come to think of it though... I've never actually tried on a mazak... at least not on one with a mazak control. There could be some weird parameter thing on the G43 when using negative offsets... have to look...
    It's just a part..... cutter still goes round and round....
  1. Trouble with tool offset VF-2
    By LorenzoNH in forum Haas Mills
    Last Post: 01-30-2007, 09:12 PM
  2. help with turning tool offset
    By Shizzlemah in forum AjaxCNC Control Products
    Last Post: 09-20-2006, 04:36 PM
  3. Tool offset ...
    By patrickb in forum Fanuc
    Last Post: 08-21-2006, 11:53 AM
  4. Tool Offset
    By 3rdcoast in forum Mach Software (ArtSoft software)
    Last Post: 05-19-2006, 02:08 PM
  5. How to set up Tool Offset in MACH2?
    By High Seas in forum Mach Software (ArtSoft software)
    Last Post: 09-09-2004, 01:54 PM
