Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol
Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here!
Old 03-07-2007, 12:18 PM
kevotron is on a distinguished road
Text file with NC code - what's needed so that Mazak can run this?
How do I take a .txt file with NC code on it and upload it to a Mazak H630 so it will run. Does that file need to be converted into something to do this? If so what program would I need for conversion? I have Mazacam, would that do it?
Old 03-08-2007, 06:14 AM
bean79au is on a distinguished road
You can convert it to mazatrol cmt format using MazaCAM and upload it. It will still be an eia program when in control not mazatrol. To do it, open up MazaCAM utilities, goto Make Mazatrol menu>Make Mazatrol From Geopath, then in the File extension box, change it from GTF to NC format and then select the file you want to convert. This will make a .bin file for you to transfer to your machine via CMT. Hope this helps.
Beau
Old 03-08-2007, 08:34 AM
OK worked thus far. My only concern is that the program that output the files (FeatureCam), took the design and made 4 files.
thread.txt
threadM01.txt
threadM02.txt
threadM03.txt
I made the assumption then to just cut and the paste the code all into one continous file. Does this sound feasable? Here is the last few lines of thread.txt and the beginning lines of threadM01.txt. The first line of threadM01.txt comes right after the last line of thread.txt Is it possible to look at this and see if it makes sense?
N1650G1X1.0233Y1.613
N1655G0Z1.0
N1660M09
N1665G0G28G91Z0M5
N1670X1.0233Y1.613M6T1
N1675M30 end of thread.txt
%:thread01 beginnning of threadM01.txt
N15G1X1.3513Y1.3882F19.5
N20G2X1.3587Y1.3505I-0.6013J-0.1382
N25X1.6763Y1.3412I0.1413J-0.6005
N30X1.6898Y1.3898I1.3237J-0.3412
N35G3X1.768Y1.4287I0.0192J0.0594
Do you think that was what I was supposed to do with the 4 txt files the program output from the design? I hope this makes sense.
Old 03-08-2007, 02:45 PM
Ok figured it out, nevermind. But I have another question...
text data to G code? zcases G-Code Programing 14 11-14-2006 08:12 AM
g code mazak robs_96 Mazak, Mitsubishi, Mazatrol 8 10-16-2006 02:17 PM
EIA file transfer to Mazak Fusion grunemh Machine Problems, Solutions , Wireless DNC, serial port 3 02-23-2006 11:28 AM
Mazak alarm code 323. Need help please. RMagnusson Mazak, Mitsubishi, Mazatrol 8 02-20-2006 03:05 PM
Saving a Text file? Scott V BobCad-Cam 4 11-23-2004 08:27 PM
