| Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here! |
pls help .i have leadwel m/c mcv.0 with mitsubishi control . i want remove 4th axise. because its no working and also idont want to use so wich parameter can disable 4th axise. thanks. |
| Hi, Does anyone have a servo amplifier unit for a (mitsubishi Meldus-M Control) Leadwell MCV-O vertical milling machine. It does not matter if it requires repair. Can anyone please tell me where I can purchase a second hand one, and lastly can i switch a 4th axis with its own power without this card? Thank you. Louis. |
| m.amir, to remove the 4th axis: - Go to your Tool/Param screen. - Press the "Next" button. - Press "Axis" at the bottom of the screen. - Press "Next" 3 times to get to the 4th axis screen. - Change #4 "Axis release" to "1". You should be able to power off the machine and remove the 4th axis. When powering back up, the control should not look for the 4th axis and there should be no alarm. |
| post processer Mitsubishi control | bala955 | Daewoo/Doosan | 0 | 12-23-2006 11:45 PM |
| Threading tapers on Fanuc control or Mitsubishi | Tyler Durden | G-Code Programing | 4 | 04-04-2006 10:08 PM |
| mitsubishi meldas control trips breaker | imwllc | General Metal Working Machines | 4 | 07-30-2005 12:02 PM |
| Mitsubishi Control help | justin | General CNC (Mill and Lathe) Control Software (NC) | 2 | 03-14-2005 06:06 PM |
