Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol
Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here!
Old 02-16-2007, 12:01 AM
Castle1 is on a distinguished road
Restarting in mazatrol program
I am trying to figure out how to restart to a certain peck depth, after having stopped the program. We are face grooving with several peck depths, I can restart at a process # but not at those numbers with a dash after (Process no. 4-18 etc). The controll is a T Plus, Mazak Qt 15N ,Mazatrol program.
Does anybody know how to restart in the middle of program and certain peck without having to cut air to get back to point left off at?
Old 02-16-2007, 02:05 AM
WayneHill's Avatar
WayneHill is on a distinguished road
No, it can not be restarted in a mid cycle process.
Break the process up into sections.
Wayne Hill
www.codemangler.com
Old 02-16-2007, 08:24 PM
Newby2 is on a distinguished road
Find out what depth you stopped at, then change the starting point of "Z". This should allow you to rapid into just before where you stopped. Start about .008" before the actual depth of the groove. Be sure to change your starting point back to the original "Z" before running the next part.
Steve
Old 02-17-2007, 07:12 AM
WILLwork4money's Avatar
WILLwork4money is an unknown quantity at this point
How deep is your Face Groove? Why do you need to stop and restart the Face Grooving Cycle? I for one try to avoid "Pecking", if a chip gets stuck in the groove when your groover comes in for your next peck it will chip the insert, been there done that!!
If your problem is with chips building up, try using an insert with a chip breaker built on to it! And, I go along with "WayneHill" and "Newby2", besides "Pecking" only adds time to your Cycle!!!
WILLwork4money
Old 02-18-2007, 11:05 PM
Depth of face cut
The part is 6" OD and the face pocket is over 1.500 Deep, Cast Iron, the ID is 4.500 max and leaving a hub of .875. It has a few contours in the bottom. The Stopping and starting, well it varies on the reasons why usually just quitting time, sometimes having to change the tooling. I've run a Hurco mill and I can restart at any peck level, so I was hoping The Mazak would do the same.
Old 02-22-2007, 07:41 PM
echokid is on a distinguished road
Why?
"Newby2" is right you can not restart in the middle of a process. If the problem is quitting time why are you stopping while it is the middle of the grove? Finish the grove and then punch out.
Old 02-22-2007, 09:17 PM
Any process in Mazatrol T Plus can be restarted at any point within that process if one knows exactly how and what that process does. It is just a matter of modifing the the numbers within that process, the programming, to have it start where you want, X and Z included. If your face groove is, say, .485 deep in Z, then change the starting point of Z in the program for that process to .480. The tool should rapid to .008" before Z 0 and the programmed X point; then it will rapid (G0) to .480, then feed (G1) to the destination point required at the speed and feed previously programmed.
Steve
Old 02-24-2007, 05:33 PM
chipmaker77 is on a distinguished road
could you take it to the depth you need and then start a new process to finish to the correct depth
Old 02-24-2007, 07:04 PM
There is no need to add another process to the program...simply change the starting point of Z. Be sure to change it back for the next part
Steve
Old 02-24-2007, 08:08 PM
I've got it, Thanks
Thanks Alot all you guys, for the help, I've got an idea of where to go from here now, here is an attachment of the part in question, it's a jpeg. In case you guys have other suggestions on how to go about machining this type of face pocket. It was tricky finding a long enough grooving tool and had to make a special holder.(alot of chatter)
  #11   Ban this user!
Old 02-25-2007, 12:36 PM
We run something quite simular to this and use a bar out/ bar in process utilizing a trepanning tool with a .236 wide insert. with a .04 DOC, sounds like a foghorn but gets it done. The corners of the insert are used as 2 separate tools, eg 7 &7A. This configuration allows the ID, in your case, the 5.125 dim, and the OD, again in your case, the 1.375 dim, to be individually adjusted in the offset page.
Steve
  #12   Ban this user!
Old 03-02-2007, 10:48 PM
CNCRim's Avatar
Have you try TPS. Check your operation manual.... you can restart at middle of the cycle.
Mazatrol program B-axis help CNCRim Mazak, Mitsubishi, Mazatrol 3 05-03-2010 08:20 PM
Mazatrol Program into a G Code Program fuzzman Mazak, Mitsubishi, Mazatrol 14 02-08-2010 03:55 PM
Stopping and Restarting in a Program Dugg Haas Mills 5 01-14-2007 03:32 PM
iso program within mazatrol (mazak VTC200C) Bodie Mazak, Mitsubishi, Mazatrol 2 09-07-2006 06:38 PM
restarting in mazak Jnicely Surfcam 1 02-22-2006 08:21 PM
