Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol
Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here!
Old 02-09-2007, 04:27 PM
DublJ is on a distinguished road
Mazak Mill Circular Interpolation problem
I run a 91 Mazak AJV35/60 Milling center at work. Recently we have noticed that when circle milling or boring with an end mill that the hole is out of round. About .007" difference between X & Y. This occurred after we sent the Y axis servo to be repaired and reinstalled. I compared the parameters of the mill to the previous parameters before the repair and they matched. However I still think the problem is parameter related because the machine performs other positioning functions accurately. Does anyone know which machine parameter I should be looking at or have any insight on this problem?
Old 02-13-2007, 08:19 AM
newguy81 is on a distinguished road
My M-2 machine do the same thing if I use the Mazatrol function. If I program in the manual unit it is fine. I asked Maszak in Kentucky a year ago at a class I took on M-2 and they said they didn't believe it. If you get it figured out let me know.
Old 02-13-2007, 11:13 AM
psychomill is on a distinguished road
Sounds like you need to bring someone in and have the servo(s) dialed in on a Ball-Bar. Never seen one go out that far but there are parameters that control the motor/screw movements. Is the problem just in certain areas of the machine or doesn't matter where? Does it change if you slow down or speed up? Does it change depending on the size of the arc? The answers to these may help to isolate the problem.
The issue with Nervis... I've seen that before too on the older controls. I always believed it to be comp related in some way. Never pursued the issue much though I'm almost always programming in G-code anyway (for mills).
It's just a part..... cutter still goes round and round....
Mazak VTC 41 memory problem kamran67 Mazak, Mitsubishi, Mazatrol 2 09-07-2008 06:57 AM
Fagor 8055 Mill Sample Code and Helical Interpolation sailcam G-Code Programing 3 10-12-2006 06:37 AM
question about circular interpolation warpedmephisto Benchtop Machines 13 03-22-2006 04:51 PM
CMT problem mazak t32-2 Enda Mazak, Mitsubishi, Mazatrol 1 02-09-2006 03:19 PM
circular interpolation of small deep holes rchprks General Metalwork Discussion 9 11-25-2005 08:37 PM
