Results 1 to 7 of 7
Thread: Forklift ran into our little QT10..help!
    Registered carbidecraters's Avatar
    Apr 2005
    Ok so what did it destroy? I know one is chuck pressure (the round guage) but what was the other guage? I want to relocate these on top in front of the lathe. Also what type of pressure guage should I buy for the chuck? 0-10psi or 0-50??? I am lost
    Apr 2005
    Oct 2006
    ireland
    I have a QSH 10 which I am dismantling for spares .the pressure gauges are mounted front top left If you want I can check the pressure range on these for you . This is a four axis machine with a CAM T4 but looks the same as yours in the area you photographed
    Apr 2005
    Yes that would help! thanks!!
    Oct 2006
    ireland
    Sorry for the delay. Both gauges are 0 to 1000 psi but normal operating pressure is indicated with a green mark at 500 psi --hope this helps
    Apr 2005
    500psi of chuck pressure? I thought chuck pressure was not over 100psi
    Oct 2006
    ireland
    email me bertietaggart04@eircom.net and I'll send you a photo
  • Posting Permissions
