I have installed Mistsubishi systems and have had no real problem with the RS232, I am not familiar with those control numbers, One common mistake is to omit to assign the correct port, there is usually a minimum of 2 ports to connect to.
I would also use a three wire cable that jumpers the hardware handshake out either end.
LinkBack URL
About LinkBacks
There is nothing fancy about the cable, it is usually easy to make up.
