I'm not a Mazak expert, but it sounds like your machine skipped a pocket in the tool changer or you need to fool the control into thinking something else. Most of the Mazak programmers have to Lie to the machine to get things to work. If this works Great, if not maybe someone with a lot more knowledge of Mazatrol will swing by to help.
One other thing, if you didn't call the tool pocket AKA Tool Number in MDI before setting the height this will happen too.
I hope this is a simple quick fix for you.
LinkBack URL
About LinkBacks
. Went back to tool data and sure enough it still read 12.#### paged through the various lists etc didn't find any offsets or wear values to cause this, all were set to 0. I managed to work around it in a so so manner by extending the insert just far enough to touch the tool eye correctly and then set it back in and reset the X on the tool eye. I had to get these parts out right away so I did what I had to, but I'd rather leave the Mickey Mouse stuff to Disney. I'd greatly appreciate any help that anyone could offer.
