Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol
Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here!
Old 07-28-2006, 11:57 AM
ajl6549 is on a distinguished road
Talking Restarting an EIA subprogram
How does one do a restart on a mazatrol prog. that has an EIA prog for a sub? (Say you want to restart in the mid. of the EIA sub.)
Old 07-30-2006, 06:30 PM
doug6949 is on a distinguished road
I am rather new to Mazatrol, however, I don't think it is possible to start within a sub. Mazak makes things even more difficult with EIA because the control doesn't evaluate program modals when restarting this type of program.
Old 07-30-2006, 07:23 PM
Thanks for your response. I found out from mazak that this not possible.
Old 07-31-2006, 08:10 PM
Razali Md.Hakim is on a distinguished road
your need post processor , I will send free to you but for Mill only
Old 08-01-2006, 06:50 AM
We are using a 640mt pro control on a 400-3 integrex. The real prob is that the tail stk., chuck, and tool barrier's don't work(at least not very well) with EIA programs. So as a solution we were going to try using our EIA prog. as a sub-program within a Mazatrol prog. This make the barriers work fine, but dosen't allow for a mid-prog. restart from the mazatrol prog. (i.e. we'd have to rerun the whole sub-prog.)
Old 08-08-2006, 04:07 PM
billder is on a distinguished road
EIA restart
Have the EIA program called as current Work #
From the POSITION screen, hit the DSPLAY SELECTOR KEY, (#3 in the Operating Manual) far left key under the screen, until you see:
WORK OFFSET MACRO VARIABLE EIA MONITOR
hit button under EIA MONITOR
cursor to point in EIA program you want to start at, hit the button under RESTART2 NONMODAL
your EIA line will go black background, hit cycle start and you are good to go.
I have used this procediure many times and it works fine on our 640MT-Pro.
REMEMBER to drop RAPID DOWN until you know exactly what your machine will do.
Good Luck Mr. Phelps
Old 08-09-2006, 06:06 AM
The EIA prog. is acctually a sub-program of a Mazatrol prog., and in order to have the tail, chuck, and tool barriers working properly, the Mazatrol prog must be the current program.
