Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol
Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here!
Old 07-12-2006, 08:31 AM
maramb is on a distinguished road
Question Mazak Integrex 200 III St ISO/EIA
Machine : Mazak Integrex 200 III St whith 2 spindels, 1 lower turret (for lathe) and 1 upper turret whith a tool magazin 40 pcs
I want to repeat in ISO the code on my Mazak whith a produkt counter, I have tried the DO1 and GOTO options.
The problem is that when I jump up to the beginning of the code,where the counter should be set to +1 one of the turrets doesn't get any code (depending on the G109L1 or G109L2), it's got to do something whith the waiting codes I guess but I can't find what it is.
has any of you had these problems and how did you solve it ?
thnx
http:\\www.adcos.nl
Old 07-13-2006, 08:32 AM
ajl6549 is on a distinguished road
The parts counter may not work with eia/iso only mazatrol. If you use mazatrol in the " end line " it asks parts count? (y/n)? but eia/iso...?
Old 07-15-2006, 03:45 AM
you may be able to use a mazatrol prog as a sub and turn on the counter that way???
Old 07-16-2006, 05:35 PM
I am building a postprocessor for Mastercam and we want to put out a program that is 100% correct, we are going to "disable" the mazatrol controller !
so it should be only ISO code !
http:\\www.adcos.nl
Old 07-17-2006, 05:15 AM
EVERFABCHAD is on a distinguished road
Run a Mazatrol sub in your EIA program
Old 07-17-2006, 02:35 PM
that is an option, but I would like to find a way to put in my NC-code without any sub programs
http:\\www.adcos.nl
Old 07-17-2006, 09:47 PM
I would say to contact your mazak dealer tech support maybe they can help. But i'm fairly shur it's an feature for mazatrol only.
Old 07-18-2006, 08:42 AM
pfffff, typical Mazak to add options in the mazatrol that can't be used in ISO.
I've contacted the tech supplier but it seems to be tough to answer questions for ISO code, they can tell you everything about mazatrol
thanks for your answers, I'm still gonna try to get it to work
http:\\www.adcos.nl
Old 07-18-2006, 11:29 AM
Try to make a "dummy prog" in mazatrol, just enough lines to let it read. In the end statment say yes to counter. Next, run it w/single blk on and observe buffer or next portion of the display esp. when it reads the "end statment" you may be able to catch a few " oddball M or G codes and one of theses mite make the counter work???, good luck... never mind the above doesn't work. It looks like a mazatrol sub prog might be your only opption. On the plus side I did try the sub. idea on ours (640 m control) and it works fine. If you need help with the Mazatrol sub. write back I can give you an sample.
Old 07-19-2006, 02:16 AM
I'll wait 'till my tech supplier answers me and let you know when I tested the file on the Mazak
thnks for the example option but I still want to solve this in the Post
http:\\www.adcos.nl
  #11   Ban this user!
Old 07-23-2006, 11:29 AM
CNCRim's Avatar
I don't know what you try to do, but I believe that you are program counter in macro I see you used DO and GOTO. I recommend you should use While...DO don't use GOTO. If you have use GOTO statement I believe if you have a long program the machine will give you about 1 second pause because it have to look throught program from head to bottom. For WHILE loop it more efficent.
I don't his the example you look for:
#100=1
While[#100GT180]DO 1
G1 XYZ..
XYZ......
XYZ.....
M253(Part counter if I remember it right)
#100=#100+1
END 1
hopefully It will help you.
  #12   Ban this user!
Old 08-11-2006, 10:10 PM
Integrexman is on a distinguished road
Here is a new forum just for mazak Integrex machines http://integrexmachinist.com/.
