Page 1 of 2 12 LastLast
Results 1 to 12 of 15
Thread: up loading a cnc program
    fjd
    fjd is offline
    Registered fjd's Avatar
    Jul 2003
    I have predator editor on the laptop at the machine
    I can get the Heidenhan TNC 310 to dump to the laptop
    but have been unable to upload to the control if any one has
    any ideas let me know
    fjd
    Registered Rekd's Avatar
    Apr 2003
    teh Debug Window
    1st make sure the settings on both the pc and the controller are correct and that your baud isn't too high. Second check the pins on the cable to make sure they're wired correctly.
    Also, do a search on the forum as this has been covered a few times and you might find something in the old posts.
    'Rekd
    Matt
    San Diego, Ca
    ___ o o o_
    [l_,[_____],
    l---L - □lllllll□-
    ( )_) ( )_)--)_)
    Community Director cadcam's Avatar
    Apr 2003
    What version of the editor are you running?
    You say you re able to get a program in to the laptop from the control correct?
    So you have checked all the settings?
    Cadcam
    Owner, contract Programming and Consultant , Mastercam Instructor and on line trainer at www.eapprentice.net
    Some tips: http://www.youtube.com/PrecisionProgramming
    fjd
    fjd is offline
    Jul 2003
    predator 5.1
    correct the down load to the laptop is great.
    i do see some chacters at the end of down that i don't know
    what the are .
    also the begining line of down load is sting od box looking chacters.
    FORD = First On Race DAy
    Apr 2003
    Make sure the first chacter is a % and one at the end.
    Ok this is our older editor.
    Cadcam
    fjd
    fjd is offline
    Jul 2003
    cadcam
    is there a place to set these chacter's so
    that it would work every time?
    thanks
    Apr 2003
    teh Debug Window
    My communication program has the option to test the outgoing file for the % and send it before it sends the program...
    For some other options, look here . Or do a search for serial or comm* and stuff like that.
    HTH
    'Rekd
    Matt
    San Diego, Ca
    ___ o o o_
    [l_,[_____],
    l---L - □lllllll□-
    ( )_) ( )_)--)_)
    Aug 2003
    UK
    hi fjd
    the first thing you need to do is go into mod functions and look
    if option is set to fe if it is that is the problem
    fe protacal is the setting heidenhain use for there software ie:
    tnc remo and will allow it to blockwise transfer but it allows to send files from the controller to a pc but you cannot send back
    so go into mod functions
    and change your setting from fe to ext1
    then try again this should cure your problem
    best regards
    peter
    fjd
    fjd is offline
    Jul 2003
    Thanks peter for the reply.
    As soon as lunch is over i will give it another look.
    fjd
    Aug 2003
    UK
    hi fjd
    also if this does not work which i think it will
    remember in your file you recieved from your m/c to your laptop
    and you said there was funny characters at the begining and at the end cut them out and paste to program you are trying to send
    but i think these are what tnc outputs for the fe protocol
    best regards
    peter
    Sep 2003
    Atlantis
    FJD, why don't you use TNCServer or TNCRemo for the transmission to the TNC. It is available from the Heidenhain website free of charge (just download it), choose your controller and baud rate and no more settings are required. The latest version of TNC server also handles remote request.
    fjd
    fjd is offline
    Jul 2003
    peter
    its still not working i even tried to just send the same
    programme back that i had just down loaded.
    Mouldmaker
    Thanks for the info I wasn't aware of those softwares
    will see if i can find them.
    thanks again
    fjd
  • Page 1 of 2 12 LastLast
    1. Gcodein - lisp program to read cnc files into autocad
      By wjbzone in forum Autodesk Software (Autocad, Inventor etc)
      Last Post: 05-10-2006, 09:08 AM
    2. Learning to Program CNC Turning Center
      By Farmer in forum G-Code Programing
      Last Post: 09-12-2005, 01:03 AM
    3. How to program G10 for Fadal CNC ?
      By giengtet in forum General CAM Discussion
      Last Post: 11-20-2003, 11:31 PM
    4. New CNC Controller Program for DOS
      By manfong in forum Product and Manufacturer Announcements
      Last Post: 10-10-2003, 12:30 PM
    5. MDT flow wires to program cnc 3d
      Last Post: 06-24-2003, 08:59 AM
    Visitors found this page by searching for:
    Nobody landed on this page from a search engine, yet!
    SEO Blog
