Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol
Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here!
  #13   Ban this user!
Old 12-13-2007, 06:45 AM
Mark18969 is on a distinguished road
Did you find an afforadble program to convert from Mazatrol language to "G" Code? I am looking for this also. Any recomendations would be appreciated.
  #14   Ban this user!
Old 12-21-2007, 03:43 PM
MrMazak is on a distinguished road
Smile Mazatrol G code conversion
I use Mazacam from Solutionware Inc. It works fine for most CNC controls. Using the G code conversion from the Mazak control will not work for other CNC because it uses codes that other controls do not use. Griffo does a simple conversion to code but as far as I know it is just generic code and you have to edit it for your control before you can use it.
  #15   Ban this user!
Old 02-08-2010, 03:55 PM
APACHE is on a distinguished road
SOLUTION WARE WORKS THE BEST YOU CREATE THE CAD AND CAN POST
IN MANY MACHINE CODES JUST G CODE OR TO THREE OR FOUR MAZATROL
MACHINES.YOU CAN DO IT IN G CODE AND PRESS MAKE MAZATROL AND IT IS DONE IN ABOUT 1 SEC. SYSTEM IS A LITTLE PRICEY I THINK WE PAID
ABOUT 18,000.00 FOR LATHE AND MILL PACKAGE
