Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol
Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here!
Old 02-06-2006, 10:42 AM
drill is on a distinguished road
Turning A Grinding Wheel
Like to know if I got a diamond tip dresser and fab it on a tool dolder
would that be a good thing dor making dies are is this a pipe dream.
Old 02-06-2006, 11:14 AM
mxtras's Avatar
Silver Member
mxtras is on a distinguished road
I think a little more information and a bit more clarity would help here......
Scott
Consistency is a good thing....unless you're consistently an idiot.
Old 02-06-2006, 01:23 PM
Sorry, I run a cnc lathe in a toolroom and was wondering if
I got a arbor to mount a grinding wheel on is it possible to but a good or complex profile on the wheel, as long as the dresser was programed right.
Old 02-06-2006, 05:11 PM
pauluk is on a distinguished road
Apart from spreading abrasive dust all over the lathe, the biggest problem I can see is ensuring the wheel runs true on the grinder. Most wheels are shaped with an optidress or similar mounted on the grinder, so it is guaranteed to run true. Personally I would not even try it, but that’s not to say it can’t be done.
The simplest things confuse the cleverest minds
Old 02-06-2006, 08:24 PM
timlkallam is on a distinguished road
Yep it will work . At work we had an old cnc lathe we put compicated profiles
on 20 inch grinding wheels for general electric. The trick is the arbor must be
machined in the lathe so it will run dead true we just left it in the lathe
and also the grinding wheel must have its wheel hub mounted on it. Don't take the wheel hub off . Also us lots of coolant to keep the dust down.
Tim
