Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol
Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here!
Old 02-02-2006, 03:37 PM
pete v is on a distinguished road
Meldas 500
Need Some Help On How And Were To Input Cutter Comp Using The Meldas 500 Contoller On A Cnc Mill..
Old 02-03-2006, 11:35 AM
2_jammer is on a distinguished road
Hi Pete-
I run a VMC with a Meldas 520 controller. The way I activate cutter comp is I call out G41 Dxx in between the height plane (rapid plane) and the first 'Z' move into the part. In other words, you need to use the G41 (for climb cutting) and a D for the tool you are using. EX. G41 D07. Now in the tool length offset page there is a column that is labeled wear. In this column, the cutter comp will be entered as a negative for the appropriate tool. EX. -.005. This will add a total of .010" of cutter comp. I hope this helps you. Shane.
Old 02-03-2006, 12:01 PM
no wear in machine
i only have tool offset ,life work, and registry.. no wear
Old 02-03-2006, 02:01 PM
coondog_28 is on a distinguished road
In your tool offset page if you do not have a radius column, enter your tool radius in an empty length offset and us a G41 Hxx instead of Dxx.
Old 02-08-2006, 05:17 PM
Thanks Ill Try It
