Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol
Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here!
Old 01-07-2006, 03:59 PM
nervis1 is on a distinguished road
Parameter to change for barrier control on a T2 lathe
I need to adjust the barrier parameter on a T2 lathe control. Anyone know which one it is?
Old 01-08-2006, 10:45 AM
Al_The_Man's Avatar
I assume you are looking on the Barrier page (5/7) ?
I have never changed these, and do not have what each represents, but I guess in the absence of any further info. you could experiment by changing the first obvious ones like
BAR: OUT
:IiN
:FCE
AL.
Old 01-08-2006, 01:22 PM
I found it in the manual (One of 15 I got with the lathe). Took a bit to dig it up.
There is a soft key in that menu in the T2 for barrier teach, each tool has a chuck and tail stock barrier you can set.
Old 08-28-2008, 04:16 AM
extapulse is on a distinguished road
Hi,on a fanuc 21i-tb lathe the barrier menu is not open.How can i activate it?What is the paramater of it and which byte should i change.
Thank you
