Need to adjust the angle on the A axis. Currently when programmed for 14 degrees is will rotate 90. I'm certain it's a parameter but which one?
"Fire is cool" -Beavis
When you command table A to move by 14 degrees in relative displacement, it moves by 90?? If you mean absolute, check your offsets.
