Results 1 to 6 of 6
Thread: Mits 4A
    Nov 2011
    canada
    Unhappy Mits 4A
    what mean alarm Z 70 0008 ?
    Jan 2011
    You might need to check your information on the model you've identified
    Mitsubishi never produced a model 4. The controller series
    went L0, L1, L2, L3, L300 L500 and so on.
    Either way a Z70 alarm is thrown when your machine looses its
    absolute position information (i.e. your machine home has been lost)
    This problem usually occurs when a - a battery went dead, or there's a
    bad encoder.
    You can download the correct instruction/operation manual from
    meau . com in the US, and there will be instructions on how to
    reestablish you home positions.
    Mar 2009
    I think he's referring to the machine model MH4A.
    Nov 2011
    canada
    yes it is MH 4A
    Jan 2011
    If it's an MHI machine with a Mitsubishi control, then you
    will want to verify the controller model number by looking
    at your diagnostics screen or the model number of the control.
    These machines might have come with a M500 or M600 controller
    from Mitsubishi Electric.
    THE Z70 alarm means that your absolute position was lost,
    as noted in my previous post.
    Once you establish what controller model you have, you can
    download the correct manual from www. meau . com to
    see how to reestablish that postion information
    Nov 2011
    canada
    there was bad encoder cable...thanks for help
    1. Mits motor
      By dim371 in forum Mazak, Mitsubishi, Mazatrol
      Last Post: 02-04-2012, 03:22 AM
    2. mits fx10 k
      By moldman3 in forum General Waterjet
      Last Post: 11-09-2011, 10:57 PM
    3. Mits DWC-90
      By mdynac in forum General Waterjet
      Last Post: 10-08-2010, 08:23 PM
    4. Mits EDM schematics
      By new2kit in forum General Waterjet
      Last Post: 04-26-2010, 03:26 PM
    5. mits mv65c
      By positiverake1 in forum Mazak, Mitsubishi, Mazatrol
      Last Post: 01-01-2008, 01:15 PM
