| Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here! |
I am using g52 in a program after a g54. Sometimes, it will not cancel, and when running a new similar problem, the move to the g54 is all screwed up. Running on Fanuc 18i-mb5 control on a Fadal. Can anyone tell me what I am doing wrong? My understanding is that the g52 x0 y0 should cancel it...... but it does not always work. When this problem happens, the only fix is to reboot the control, then the g54 moves to the proper location again.??? % O1 ( 1.7500 PARALLEL HEIGHT ) ( FRIDAY 12/2/05 12.02PM ) G00 G20 G53 G00 Z0 G40 G53 X0 Y0 G52 X0 Y0 Z0 G90 G55 G00 X0 Y0 G52 X-2.5000 G52 Y0.0000 G52 Z0.9500 M09 G10 L10 P2 R-17.1405 G10 L12 P2 R0.0000 M6 T2 T5 G00 X-1.2500 Y-0.5 G43 Z3.1000 H2 D2 M00 M00 M00 M00 (* SET EDGE TO POSITIVE STOP WITH 1.0 JOE BLOCK) (* WHEN DONE, PRESS MANUAL, START, 1 TO RETURN AXES) (* PRESS START AFTER AXES STOP MOVEING TO CONTINUE) M09 G10 L10 P5 R-18.5665 G10 L12 P5 R0.4990 M6 T5 T2 S2292 M3 M08 G10 L12 P1 R0.4990 G00 X5.5532 Y-3.7025 G43 Z0.1000 H5 D1 G00 Z0.0100 G01 Z-0.0250 F3.4500 F13.8 G41 G01 X5.8027 Y-3.7025 G01 X5.8027 Y-2.8500 G01 X-1.0135 Y-2.8500 G00 Z0.1000 G40 M08 G10 L12 P1 R0.4990 G00 X5.5532 Y-3.7025 G43 Z0.1000 H5 D1 G00 Z-0.0150 G01 Z-0.0500 F3.4500 F13.8 G41 G01 X5.8027 Y-3.7025 G01 X5.8027 Y-2.8500 G01 X-1.0135 Y-2.8500 G00 Z0.1000 G40 M08 G10 L12 P1 R0.4990 G00 X5.5532 Y-3.7025 G43 Z0.1000 H5 D1 G00 Z-0.0400 G01 Z-0.0750 F3.4500 F13.8 G41 G01 X5.8027 Y-3.7025 G01 X5.8027 Y-2.8500 G01 X-1.0135 Y-2.8500 G00 Z0.1000 G40 M08 G10 L12 P1 R0.4990 G00 X5.5532 Y-3.7025 G43 Z0.1000 H5 D1 G00 Z-0.0650 G01 Z-0.1000 F3.4500 F13.8 G41 G01 X5.8027 Y-3.7025 G01 X5.8027 Y-2.8500 G01 X-1.0135 Y-2.8500 G00 Z0.1000 G40 G9 M5M9 (* DONE *) M6 T2 G52 X0 Y0 Z0 G43 Z0 H0 D0 G53 X0 Y0 M02 % |
| Can you explain the G10's? I'm not familiar with them enough to know what it is that you are changing. Something to do with tool offsets, or work offsets?
| REVCAM_Bob You do not have any G54 commands in the program you list, just one G55 so all your G52 commands will be working from G55. Hu G10 enters tool offsets and work coordinates from the program. L10 is length offset, L12 diameter offset. The Haas manual describes the use of G10 in a somewhat understandable manner. |
| I'm lost as to why you need to use the G52? G52 is local coordinate shift. just add the values to G55 offset. This does not answer your question, but there are some parameters related to G52 that could be affecting you. One parameter is weather of not M00/M01 cancels G52 Reset/M30 should also cancel it. |
