Sounds like you don't have the option for complex offsets.
Hi, probably a stupid question but does any one know where to find the screen to enter in the tool diameters on the M3 all I have is a length offset page.
Also does any one have a pin layout for the communication cable to drip feed the machine, its a leadwell MCV 760.
With regards
Will
I had the same issue. The memory was overloaded and the machine stopped completely. (What a great thing to happen only three weeks on a new machine and control) I called MEAU and they told me to reformat the memory. In the process of doing so I lost the Type II tool offset page. The machine was up and running but had no diameter offsets. I contacted MEAU once again about the new issue and they told me it's a purchased option. I explained that I already had the Type II page and when I reformatted the memory it changed it to Type I. They didn't seem to care and told me they would call me back. This was back in February of 2012 I believe. I'm still waiting on that call. I found some information on the internet and it worked. Change Parameter 1037 cmdtype from a 1 to a 2. Then reformat the memory. If you need more information I would gladly be able to explain.
Shane
shane347921@yahoo.com
Oh, and by the way. If you're an old stubborn machinist that knows it all. DON'T CONTACT ME!
I must have missed this post since it was done in June,
but the type II tool offseting (length, and radius, and wear) was
indeed an option on the M3 when it was purchased in the early 90's.
What you can do is put length in 1 for example, and use 11 for diameter
The parameter (1037) identified by another post was not available
on the M3 control ( infact that parameter was not available until Mits
launched its 600 series in late 90's).
The communication pin-outs for the RS232 is :
from 25 pin to 25 pin
2+3 crossed
4+5 jumpered together on each end
6+8+20 jumpered on each end
7 straight thru
The year and model appears to be different than yours. Best of luck to you.
