Results 1 to 5 of 5
Thread: How to transfer data using RS232 step by step in mitsubishi meldas 500?
    Mar 2012
    indonesia
    Dear all,
    I'm new member here.
    I ussualy using fanuc controller, and I have problem with old machine (no manual book), mitsubishi machining center using meldas 500. But don't know step by step transfer NCdata, or using tape mode. Please help...
    Thanks all
    Mar 2012
    indonesia
    dear all
    please need the config of PC side, and machine side.
    also the RS232 config. Is same config with Fanuc cable RS232 ussualy I use?
    Thanks before
    Jan 2011
    Give me your email and I can send you a document for 500M series.
    Cheers.
    Jul 2004
    Mitsubishi
    The Fanuc cable will work on the Mitsubishi 500 series control. The trick is to set the Device correctly and then the specific Input/Output parameters. The NC running, data in/out should all be the same to eliminate possible issues. There are so many parameters here that can be mis-configured.
    Feel free to give me a call or shoot me an email and we can try to work on it together.
    Greg Mercurio -Shop Floor Automations
    www.shopfloorautomations.com /619-461-4000
    Jun 2012
    saudi
    dear all
    we hvae deep hole drilling from ixion mitsubishi control thier is error ABS 1001 07
    i need help
    mansour
    1. mitsubishi meldas 320m rs232 help
      By davidrvalencia in forum Machine Problems, Solutions , Wireless DNC, serial port
      Last Post: 08-13-2011, 12:55 PM
    2. RS232 or CAN 2.0 Step Motor Controller Supplier from Shanghai
      By uirobot in forum Product and Manufacturer Announcements
      Last Post: 03-28-2010, 10:25 PM
    3. Need Help!- Step/Direction pins should be Step FWD and Step BACK
      By rayscott in forum Mach Software (ArtSoft software)
      Last Post: 02-09-2010, 06:57 PM
    4. Mitsubishi Meldas 520 AMR RS232 Cable pinout??
      By CNC Viking in forum Mazak, Mitsubishi, Mazatrol
      Last Post: 12-23-2008, 01:18 AM
    5. Step & direction v Rs232?
      By Ross77 in forum Controller Cards
      Last Post: 01-12-2008, 02:53 AM
