Results 1 to 6 of 6
Thread: Mazak gremlins on startup
    Mar 2007
    us
    Stupid title admitted:
    I have a mid 90's QT18n T-Plus that has been acting up lately. I know the machine is old but I can't seem to part with it. It still makes me money.
    Anyhow, upon start up the screen comes on for a split second then goes blank. That's when all the good stuff starts. Parts catcher will come up, coolant will sometimes come on. The turret starts spinning (not indexing but a full on spinning).... The only thing on the screen will be the error. It will be a different error every time. Anything from over heat, zero origin and turret malfunction. It was doing this pretty often so I called a tech. So of course when the tech got here I couldn't get the machine to repeat the problem. $400 and 2 hours later, I get the "I have no idea"
    The next day the way lube system broke. I installed a new one and the start up issue went away for about 3 months without a single problem. Now its back again.
    Once the machine is fully started it will run all day. Besides the frustration of on and offing the machine to get it started up, it's also dangerous. I have spent hours searching for a fix via internet and hours on the phone. I have no issue what-so-ever of paying that $130 an hour tech fee but every tech I speak with wont touch it. If its not windows based they don't want mess with it.
    Thanks for reading if you actually got this far.
    Shane
    Jun 2008
    Sounds like instead of a tech you should have called a preist for an exorcist.
    Mar 2007
    us
    I have been waiting for the pea soup to come spewing out but, nothing yet.
    Mar 2009
    How about leaveing the machine on and just hit the e-stop at the end of the day?
    Mar 2007
    us
    Quote Originally Posted by 1234567 View Post
    Only problem there is, the fans and hydraulics will not be shut down. I came in this morning and it fired right up. I think it's waiting to fail me at the worst time possible.
    Mar 2007
    us
    I'd like to add:
    On the control panel there are 2 sets of red digital numbers referencing RPM, feed...etc. When the machines disconnect is turned on they light up all zeros before I push the 'on' button. This is normal I know but, I noticed when the machine acts up they wont light up at all before pushing the 'on' button.
    Power supply maybe???
    1. The Gremlins are back
      By scrambled in forum General CNC (Mill and Lathe) Control Software (NC)
      Last Post: 06-13-2011, 11:55 PM
    2. HL-2 startup help
      By thum31 in forum Haas Lathes
      Last Post: 06-03-2009, 07:53 AM
    3. Gremlins in the control
      By daisydog in forum WinCnc
      Last Post: 02-24-2009, 04:19 PM
    4. Mazak QT-200,Mazak VTC-160A,Mazak FJV-250 all pcb problem
      By sting_dot in forum Mazak, Mitsubishi, Mazatrol
      Last Post: 05-21-2007, 09:20 PM
    5. mm on startup?
      By bigz1 in forum Mach Mill
      Last Post: 05-20-2007, 06:44 PM
