Results 1 to 3 of 3
Thread: Mazatrol CAM-M2 and RENISHAW MP3
    Oct 2011
    France
    Unhappy Mazatrol CAM-M2 and RENISHAW MP3
    Dear All,
    I'm back in discovering my Mazak VQC20/50b fitted with a CAM-M2 controller.
    i've just repaired my automatic tool measurement unit and the tools are correctly measured.
    So i continue now i'd like to set a work piece reference....
    With the machine I have a Renishaw MP3 probe. I'm sure I have all the options in the machine because the Renishaw was in place in the tool holder.
    I have no idea how to set it. I put it in the #24 tool place but when I want to input the tool parameter I only have a "PALPEUR" in french (probably PROBE in english) tool type that seeming to correspond to my Renishaw probe.
    But how can I know the other parameter? the ball seems to be 5mm but where can I find the lenght etc...
    As usual thanks to everyone in this forum who helps some stupid newbies like me!
    Apr 2012
    the probe needs a starting point, in other words a length and diameter usualy .100 larger than the part to be checked. get a standerd, check length z, diameter x, add .100 and the there should be a macro parameter, to set for each.
    also reinshaw usely provides a g code for this but you need to position the probe within at least .100 of the part x and z.
    Oct 2011
    France
    Red face
    Thanks for you help,
    the stylus is 100mm long. But cf this manual in french (proivided with the VQC) it seems to be fully automatic.
    Obviously I need to place it in the good pocket on the rotary tool holder.
    I do not know where to find where the Renishaw MP3 probe was set?
    I think I first need to find where to place it.
    Thank you again
    Eltorio
  1. Mazak M-4 Mazatrol T2 and mazatrol Cam T2 operating manual in english
    By tuanpq in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 10-03-2012, 04:49 AM
  2. Need Help!- Sm1 well versed with mazatrol 640m or atleast ne mazatrol
    By naren1608 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 03-22-2010, 06:29 AM
  3. Need Help -- Calibrating Renishaw MP12 in Mazatrol
    By pjr170 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 04-01-2009, 10:04 AM
  4. Renishaw OTS
    By rbest27 in forum Haas Mills
    Last Post: 05-07-2008, 03:17 PM
  5. Renishaw CP1
    By Dancy in forum Calibration and Measurement
    Last Post: 01-18-2008, 10:57 AM
