Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol
Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here!
Old 11-27-2005, 08:25 AM
sunrock_83 is on a distinguished road
Mazatrol T32 Turret Clamping problem
Hello
I have Mazatrol T32 Machine. The problem is that the Turret is not clamping. When rotated it rotates for one cycle and then stops insted of clamping at station. There are 16 stations. I have checked with Encoder and Sensor and they are working fine. Please help me to find soultion on this
Byee
Old 12-15-2005, 05:15 PM
Rocksalt is on a distinguished road
Try and stop it at different tools and see if any work.
How did you check the encoder?
Some turrets have slowdown switches, is the turret servo driven or hydraulic driven?
If servo you need to look at feedback and parameters.
If hydraulic you need to look at switches. There are many switches.. say you have 8 switches. 1 clamp/unclamp, 0,1,2,3,4,5,6,7 are all going to be inputs. The combination of them switches determines position. 1 switch will be a slow down switch.
Do you get any alarms?
Jack of all, master of none
Galveston, TX
Old 12-21-2005, 05:12 AM
thnaks dude for your reply. Actually i have found that the encoder is faulty and was not able to send back the message to system properly. so now i am searching for new encoder. It is sumtak Make. can you help me out to locate one?
byeee
Old 12-21-2005, 09:09 AM
Al_The_Man's Avatar
Renco Encoders have taken over Sumtak distribution in the US, if you know the resolution and output type, it might be easy to sub. to another make if the original is unavailable.
Old 01-29-2006, 09:11 AM
Enda is on a distinguished road
You guys are lucky i hada similar problem with a T32 and we ended up having to fork out €4500 for a new hydraulic motor.
Old 02-08-2006, 11:38 AM
Genie is on a distinguished road
We had been getting a 221 and 272 alarm, we found that the switch had a short and wouldn't always read shaft position between tools 1 and 2. We pulled the switch out of the bracket and cut the wires and re-soldered a new switch. This seemed a quick fix w/ minimal down time to re-route the wire.
