Page 1 of 2 12 LastLast
Results 1 to 12 of 14
Thread: Mighty VMC-510P w/Meldas 320 - Toolchange Program Needed!!
    Sep 2009
    Hello all, my 1993 Mighty VMC-510P with the Meldas 320 just took a crap and I had to reinitialize the control, put all the parameters back, and format the memory. In doing so the toolchange program/macro got erased. I have all the documentation to the machine with the parameters/settings but they left out this important information.
    Does anybody have one of these up and running?? If so I am desperate for this program as I cannot get my machine going without it. It should be program O9890. It may be hidden but I can tell you how to access it. Or I believe you can just output that program whether it's visible under the File page or not. Please help! My machine is useless without it so any assistance is much appreciated!!
    Sep 2009
    Make that program O9020 not O9890.....
    Sep 2009
    And here is how to find it: Access machine parameters, which is going to diagnosis screen, press the PLC I/F soft key. Then type in the following Device (1001) Data ( ) Mode (M) press input, they will disappear. Then press your parameter hard key. Under the Base parameters look for a parameter edlk_C and change it to a 0. Then go to the file page and it should be there.
    I will pay someone for this guys!!
    Oct 2008
    New Zealand
    I have a Hartford VMC850 with a Meldas M520A controller, I was hoping it was similar because I'd like to tweak my toolchange program, but my edlk_c param is already 0 and I cannot access any macro programs. I'll dig out the manual and see if I can help you in any way.
    Edit: Found a helpful website "If you inadvertently lose the FIXED CYCLES, they are still stored on EEPROM so all you need to do is change FIX_P to 1, go to INPUT screen and enter #(4) and press INPUT. The FIXED CYCLES will be loaded from EEPROM."
    Not sure if that will help? http://machinetoolinfo.com/MITSUBISHI.html
    This might be similar to the program you are seeking http://www.cnczone.com/forums/fanuc/...acting_up.html or something like http://machinetoolinfo.com/YANG.html
    Good luck and let us know if any of this was helpful. Program 9001 on that last link looked promising
    Oct 2008
    New Zealand
    Taken from this forum: DynaMyte 4400M with Meldas M3 control
    But for the 520 control.
    O9001()
    N1#1=#4003
    N2#2=#4001
    N3#3=#1033
    N4#4=#4120
    N5IF[#4LE0]GOTO20
    N6IF[#4GT18]GOTO20
    N7IF[#3EQ#4]GOTO20
    N8G40G80G63
    N9M60
    N10G91G30Z0M19
    N11M40
    N12G04P500
    N13M12
    N14G04P500
    N15G91G28Z0
    N16M41
    N17G30Z0
    N18M11
    N19M42
    N20G#1G#2
    N21G64
    N22M99
    The M codes in whichever program you try to use might need to be changed to your specific machine. Do you have a manual with the M codes listed for tool clamp, magazine in / out etc?
    Sep 2009
    Quote Originally Posted by dblox View Post
    Not sure if that will help? MITSUBISHI
    This might be similar to the program you are seeking http://www.cnczone.com/forums/fanuc/...acting_up.html or something like YANG
    Thanks, I will check these links out. As far as the fixed cycles on the eeprom, I was able to do that and got all my canned cycles back. But no tool change program unfortunately.
    It's interesting you mentioned that you set your 520 edlk C off and still can't see the program. We have a newer Mighty Viper here with the 520 and the same thing happens, I can't see the tool change program at all. Weird thing is at some point I remember changing a setting or parameter on the same machine and seeing it executed step by step. But I don't remember what we did. I also found an identical machine to mine in Green Bay with the 320, and the shop was willing to help me, so I thought problem solved. But again they can't see or find the program either. Does anyone know why this is?? Is it written into the PLC side or something?
    Sep 2009
    O9001()
    N1#1=#4003
    N2#2=#4001
    N3#3=#1033
    N4#4=#4120
    N5IF[#4LE0]GOTO20
    N6IF[#4GT18]GOTO20
    N7IF[#3EQ#4]GOTO20
    N8G40G80G63
    N9M60
    N10G91G30Z0M19
    N11M40
    N12G04P500
    N13M12
    N14G04P500
    N15G91G28Z0
    N16M41
    N17G30Z0
    N18M11
    N19M42
    N20G#1G#2
    N21G64
    N22M99
    Thank you also. As far as the M codes go, I don't have the manual with me at the moment, but I think I'll be able to figure them out. Someone also posted the M codes and what they do on their Mighty some time back. What I don't understand is the rest of the program, the assignments to the registers and whatever else is going on there. Does anyone know how to decipher what's going on line by line?
    Sep 2009
    Forgot to mention, the mill is also known as a Mighty Comet, I probably should have added this in the title....
    Oct 2008
    New Zealand
    I'm 99% sure that Mighty Comet / Might Viper & Hartford are all the same MTB HARTFORD INDUSTRIAL CO., LTD-www.hartford.com.tw so you could try asking them for some info. Is there a little plaque on the machine from the builder? In all the google searches I do the Mighty Viper looks like my Hartford machine.
    Sep 2009
    Hmmmm....As far as I know the Mighty Viper (late 90s?) was the next generation VMC after the Comet. I have never seen that name Hartford on anything on my machine but it is worth taking another look. I will check out the plaque this weekend.
    Oct 2008
    New Zealand
    Hartford and Mighty Viper are just brand names, looks like Mighty Viper is the sticker they put on for the American market. Mighty USA even has the link to Hartford, which is actually She-Hong industrial which is the name I'd expect to see stamped on the back of your machine sheetmetal. Mighty USA
    With this in mind, contacting She-Hong is probably your best bet.
    Sep 2009
    I am in the process of talking to Mighty service techs but not sure how that is gonna go, depends on if they can dig up the program or not....
    But in the meantime, for anyone that has one of these Comets with the 320M, or can get access to the correct program from it, I will Paypal you $250 (providing it works of course). I need it that bad. Let me know if anyone can help.
  • Page 1 of 2 12 LastLast
    1. Need Help!- Mistubishi Meldas M520 and mighty comet tool change issue.
      By 4Rm0D in forum Mazak, Mitsubishi, Mazatrol
      Last Post: 01-16-2012, 10:10 AM
    2. Mighty comet parameters VMC-750 needed/Spindle problem
      By Petro in forum General CNC (Mill and Lathe) Control Software (NC)
      Last Post: 09-30-2010, 11:27 AM
    3. Need Help!- Program search Meldas 520
      By Brad-Summa in forum Mazak, Mitsubishi, Mazatrol
      Last Post: 09-22-2008, 05:43 AM
    4. Need Help!- Mighty Comet with Meldas M0
      By Bert10 in forum General Metal Working Machines
      Last Post: 08-02-2008, 06:35 PM
    5. Can not get to Meldas MO Program in/out screen
      By cut more in forum Mazak, Mitsubishi, Mazatrol
      Last Post: 03-14-2008, 07:34 AM
