Results 1 to 3 of 3
Thread: How to enable-Mazak nexus USB to serial ?
    Apr 2006
    india
    Post How to enable-Mazak nexus USB to serial ?
    I am trying enable USB to serial to a MAZAK Matrix nexus ,installation of the driver to Windows on the machine is successfull and appears in device manager.But I/O settings and any parameters related to TAP and DPR(COM) is not visible and I can not use the PORT,please tell me is there any parameter I need to change on the NC side ?currently NO com port setting is visible only USB and CARD and HDD option is visible.
    Thanks in Advance.
    Aravind
    Registered MrMazak's Avatar
    Dec 2007
    Attached is the Mazak procedure for USB-serial installation. Please note you CANNOT save via USB-serial using CMT mode. It is load programs only. Kind of useless I think. Just use a USB key. Good luck, I never got it to work.
    Attached Files Attached Files
    Apr 2006
    india
    Hi Mr Mazak,
    Thanks for the reply,
    I have understood this part where I have to install the drivers In windows.
    But my pain is that the COM port and settings (I/o settings,TAP,DPR params) are not showing up
    Aravind
  1. Problem- Mazak Quick Turn Nexus 200 lathe with Mazatrol 640 T-Nexus control
    By arwinder in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 06-29-2012, 10:19 AM
  2. Mazak nexus 250
    By jake93rx7 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 09-23-2010, 01:11 PM
  3. Mazak nexus 250
    By cadcamsolutions in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 09-11-2009, 03:20 PM
  4. Mazak Nexus 510
    By jamie pinols in forum General Metal Working Machines
    Last Post: 08-21-2009, 12:19 AM
  5. Mazak EIA enable parameter
    By Bakes1 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 01-12-2008, 02:17 PM
