Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol
Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here!
Old 11-19-2005, 09:07 PM
chuy's Avatar
chuy is on a distinguished road
trouble with comunnicatins on 11m
I have a kitamura mycenter 3 with a fanuc 11m control on it.. and I'm having a little trouble with the communications.. when i go to send a program to the control and hit read all or this I get this alarm "SR 820
DR off (1)" ..I have the book but it doesn't tell me what to do. It explains it as "Data set ready signal of
reader/puncher interface 1 turned off." Anyone know how I would turn it on I would assume this would correct my problem..
Thanks,
Chuy
Old 11-19-2005, 10:12 PM
Al_The_Man's Avatar
See the Cadem site for three wire connection, handshake jumpered.
Old 11-20-2005, 08:12 AM
Chris D's Avatar
Chris D is on a distinguished road
Thanks,
Chuy
Your cable is not wired correctly..
on the machine end of the cable
Jumper pins 4 & 5 together
Jumper pins 6,8, & 20 together
That should fix your problem.
Chris
Old 11-20-2005, 05:45 PM
chuy's Avatar
you mean I have too crack open my control for this?
Old 11-20-2005, 05:50 PM
Dan Fritz is on a distinguished road
Jumper pins 6-8-20
No. All you have to do is take the cover off the 25-pin connector on the end of your cable. The Fanuc end of the cable needs that 6-8-20 jumper. The Fanuc must see a positive voltage on pin 6 (DR) and pin 8 (CD) or you will get an alarm. Pin 20 is the Data Terminal Ready (DTR) output, so the Fanuc will put a positive voltage on that pin. You're just using pin 20 to hold pins 6 and 8 high.
If your CNCs serial port is damaged, this 6-8-20 jumper may not do the trick. In that case you can tie pins 6 and 8 to any pin that's "Hi" on the PC side, like pin 4 (if your PC has a 9-pin plug). Thats the DTR signal from the PC.
Old 11-21-2005, 03:05 PM
hangslot is on a distinguished road
Older Kitamura's have on the electrical cabinet a punch tape reader.
Open this, than you will see a switch at the site, be sure to switch this to 'EXT'.
Old 12-17-2005, 12:12 PM
chuy's Avatar
Finally got it to work
OK fellas I just wanted to update everyone on my situation...after all the code inputting by hand and all the crap... as it turns out it was a combination of a few things. The mastercam communcations software doesnt work on the older fanuc controls,so i got the software from cadnet works great!, also needed the null modem and last but not least the previous owner had it hardwired in and he disconnected the CD1 from the mother board so it wasn't reading the rs232 port.
Thanks,
Chuy
