If you have a Fusion 640T, there is an internet card in it that Mazak can connect with and up load the correct parameters that came with it. PSharp1
Machine goes home in both the x and z axis,but when the operator runs any programs he gets a 120 alarm that says "120 soft limit +x" as some as he hits cycle start.
I know close to nothing about this machine .He mentioned that he did change batteries with the machine powered off,could he have lost some parameters for this.Stepping through the parameters I do see some different ones than listed in the list that came with the machine.Does someone have the parameter number for the soft limit alarm so I can check it out?
Dave
Could be a tool data error and the index parameter is set to index X clearance position and you have a 0.0 in one of the tool set numbers. Make sure parameter P17 is set to 1
