Results 1 to 2 of 2
Thread: T-2 tailstock woes
    Dec 2008
    U.S.A.
    T-2 tailstock woes
    Hi all,
    Got a strange situation with my MAZAK QT-15's tail stock.
    The machine will only run with the quill fully extended.
    Anything else will result in various alarms, with 932 being the most common.
    I've tried all kinds of combinations of the tail stock forward and retracted, but the machine will not run without pressure on the extended tail stock quill.
    All the tail stock limit sensors will light up when metal passes over them.
    I am at a loss what to check next.
    Can the tail stock facility be turned off electronically to by pass it's faults ???
    This machine has a T-2 control.
    Thanks for any help!
    Dec 2008
    U.S.A.
    alarming mistake
    I realized after I posted this that the alarm message is 293, NOT 932 as previously mentioned.
    Thanks !
  1. RE- My woes with CNC......
    By kbillan in forum Taig Mills & Lathes
    Last Post: 01-16-2009, 05:22 PM
  2. Bob CAD woes
    By Mr. LocoMartin in forum BobCad-Cam
    Last Post: 01-25-2008, 03:18 PM
  3. Relay Woes
    By babinda01 in forum General Electronics Discussion
    Last Post: 07-03-2007, 05:23 PM
  4. Mach2 woes, again
    By Rustybolt in forum Mach Mill
    Last Post: 06-16-2007, 10:27 AM
  5. Z axis woes
    By yukonho in forum DIY CNC Router Table Machines
    Last Post: 02-29-2004, 01:02 AM
