Results 1 to 2 of 2
Thread: Mazatrol T1 boring bar calibration?
    Feb 2012
    Hi all,
    We have recently acquired a Mazak QT10 with a Mazatrol T1 control. Our question is: how do we calibrate a boring bar? There are no examples in our manuals. We've tried making an inside cut, hitting TEACH, stopped the spindle, measured the id, entered that value and hit INPUT (Same as for OD cut.) We're using the BAR IN cycle. Our minimum id is set at the drill id (1.1875), and CPT-X = same. The problem is when we run the part, the boring bar is cutting at least .25 away from the drilled hole surface on the finish pass. Looks like some kind of offset or parameter value is plugged in somewhere, but we can't find it. We do not have a complete list of parameter codes in our manuals; maybe about half of them?
    Any help would be greatly appreciated, thanks.
    Registered MrMazak's Avatar
    Dec 2007
    Bore a hole with the bar using the hand wheels. Measure the bore. Write it down. Touch the I.D. in the measured bore with the bar using the hand wheel. Go to Tool Set page (cursor to Tool Set X for the current tool) Without moving the bar push TEACH and enter the measured diameter and push INPUT. Your tool is set on X.
  1. Mazak M-4 Mazatrol T2 and mazatrol Cam T2 operating manual in english
    By tuanpq in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 10-03-2012, 04:49 AM
  2. Need calibration help
    By JasonCcnc in forum DIY CNC Router Table Machines
    Last Post: 07-24-2011, 10:11 PM
  3. Indexable boring bar in boring head?
    By Molochnik in forum General Metalwork Discussion
    Last Post: 04-15-2010, 08:36 AM
  4. Need Help!- Sm1 well versed with mazatrol 640m or atleast ne mazatrol
    By naren1608 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 03-22-2010, 06:29 AM
  5. Replies: 1
    Last Post: 08-24-2009, 12:19 PM
