I have a Slant Turn 30 ATC with a Mazatrol T3 and I am getting an alarm that I can find no information on.
257 C-AXIS OR SHIFT LS MALFUNCTION
when I try to switch to the C Axis. When I switch it on it rotates the chuck, slows and stops then gives the alarm. I can see on the headstock that the proximity switch is activated so apparently it is indexing to the correct position. Any help would be appreciated!
Thank you.
LinkBack URL
About LinkBacks
