Results 1 to 3 of 3
Thread: Mazak Hyperquadrex Tool Naming
    Oct 2011
    We are trying to set up a standard way of naming our tools & tool models on our Hyperquadrex. We want to make it easy and make sense. We anticipate changing tools, shanks, insert sizes, etc. often due to us being a mid-high volume job shop. Any suggestions?
    Registered MrMazak's Avatar
    Dec 2007
    Attached is an old system for mills I used back in the day. Come up with a system like this for your shop. You can use A-Z tool ID codes for each tool type. That way anyone can figure out what tool is used in any program.
    Attached Files Attached Files
    Oct 2011
    Thanks, Mr. Mazak. Your Tool ID code sheet was helpful.
  1. Request Help naming a part
    By Burnit0017 in forum Mechanical Calculations/Engineering Design
    Last Post: 05-22-2010, 04:05 PM
  2. Solid machinist and naming
    By mvas82 in forum EdgeCam
    Last Post: 07-02-2009, 04:41 PM
  3. A2100 file naming
    By kendo in forum Tree
    Last Post: 02-13-2009, 10:30 AM
  4. Mazak Qt-200 tool ID
    By Dick Le. in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 01-29-2008, 04:35 PM
  5. Naming your machine (and hold down stuff)
    By wcarrothers1 in forum DIY CNC Router Table Machines
    Last Post: 12-20-2006, 12:14 PM
