| Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here! |
HI! I have Mitsubishi HF-SP352B servo motor, with broken encoder. I want to replace the encoder ( encoder name is OSA-18 0eyw3t ) I found at ebay OSA-18 , but the following letters different ( not eyw3t) how I choose the right encoder ? Thank You |
| If it came off the same motor it should work, I know they always mention 'programming the encoder for the motor' but I have never found out what that meant? Al.
| I know they always mention 'programming the encoder for the motor' but I have never found out what that meant? Programming means they are setting the motor size data in the encoder. Its not really programming, more like setting parameter data. It is normally MRJ series servos system that require this setting not MDS to my knowledge. The motor size data is set in the encoder because the motor/encoder are normally sold as a item. The contoller / parameter data / motor-encoder combination can be therefore be varified for the correct combination at startup. |
| mits fx10 k | moldman3 | EDM Machines | 0 | 11-09-2011 09:57 PM |
| Mits DWC-90 | mdynac | EDM Machines | 1 | 10-08-2010 07:23 PM |
| Mits EDM schematics | new2kit | EDM Machines | 0 | 04-26-2010 02:26 PM |
| mits mv65c | positiverake1 | Mazak, Mitsubishi, Mazatrol | 5 | 01-01-2008 12:15 PM |
| Mits Vs. Charmilles | GOOCH | CNC Plasma and Waterjet Machines | 2 | 08-27-2004 10:57 AM |
