| Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here! |
What's up ! Need help with M2 control panel, Machine was sitting for awhile, Batteries on card test OK. We will verify the battery conditions. The screen will not change off of the possition page. Have an alarm NMI 22 Emergency stop, (The results to which the data in the main CPU system memory were added upon starting of the NC differ from wat have been registered.) We were playing with the Magazine positioner MPS510 Sequencer before it was shut down. may have messed up the parameters in here. Will this caues the M2 Control to freeze up ? I was told not. The Monitor has a FX709B Board , should the Led 1 Be lit up. It is not ?? Thanks |
DEAR FRIEND, PL CHECK THE CRT CONTROL UNIT AND IT WILL BE HAVING THE FOLLOWING CARDS FX32B FX42A FX52A FX62B There will be one led in the FX52 CARD AND IT WILL BE BLINKING IF THE DATA TRANSFER IS OK. THIS CARD IN TURN IS CONNECTED TO FX27 IN THE NC RACK. MAY BE YOU CAN DO MEMORY CLEAR OPERATION AND RELOAD THE PARAMETERS. I DO NOT SEE ANY FX709 CARD AS SUCH IN A M2 CONTROL. IF YOUR MPS510 UNIT AND YOUR DRIVE MV20/30 IS HAVING ANY PROBLEM YOU WILL ONLY GET EXTERNAL CONTROLLER MALFUNCTION ALARM MAZAK EXPERTS MAY PL CORRECT ME IF I AM WRONG. CHANDRU |
| Hi Chandru If he has an FX709 then there is only one board in the op panel. This is the second generation of the M2 controls. Tomsawyer The LD1 light should turn on in a normal situation. What other LED's are on on the boards in the control? |
Dear onthebumper, Then the controller has to be similar to Cam T3.Am I right? As many of our Mazak machines with M2 controllers are having the mentioned cards inside the CRT Then the Nc rack will be having FX727 and other cards. Some times by cleaning all the cards and checking their mounting tightness may clear this problem.Or by looking at the other LED status of the boards inside the Nc rack only we can come to some conclusion. GANESHAN |
| Problem- CL 203 CONTROL PANEL | gtrrpa | Mori lathes | 1 | 04-22-2011 02:15 PM |
| Control Panel Cut out | scruffyjones48 | Employment Opportunity | 5 | 08-03-2008 03:47 PM |
| T32 Control Panel Lock up | bean79au | Mazak, Mitsubishi, Mazatrol | 0 | 07-13-2008 04:59 AM |
| My DIY control panel | DennisCNC | CNCzone Club House | 6 | 10-02-2006 10:24 PM |
| Building my control panel | ChrisJ | General Electronics Discussion | 0 | 03-02-2005 08:09 PM |
