Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol
Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here!
Old 01-24-2012, 07:17 AM
Elecspec is on a distinguished road
Mazak M2 control communication problems
Hi guys,
I have a client with a M2 control that I've been trying to get communicating with a PC loaded initially with SDcomms(V7), but have now moved on to trying to get communication going between the control and NC-link.
The control does not communicate with the PC a all using SDcomms, even when the parameters have been checked thoroughly. The PC is loaded with windows 7, and i fear that NC-link may not be compatible with this version of windows.
When using NC-link i am able to receive from the machine, my problem though is that the program sent is not what is coming through. When sending in Mazatrol there is only one character received, a black dot, when sending in ISO i get two character, a q and a backward L.
The parameters on the machine match the ones in NC-link,
Baud rate 4800, data bits 7, stop bits 2, handshaking XON/XOFF
If anyone has had this problem before with receiving only these characters instead of the whole program, i would very much appreciate any help or advise.
Thanks very much
Old 01-25-2012, 01:55 AM
angelw is on a distinguished road
Originally Posted by Elecspec View Post
Hi guys,
Thanks very much
Describe the pin out of the cable you're using, and are you using Parity in your configuration? Generally, with 7 and 2, even parity will be used.
Regards,
Bill
Old 01-26-2012, 06:50 PM
mbi mbi is offline
mbi is on a distinguished road
Try slowing the baud rate down to 2400.
Old 01-27-2012, 04:12 PM
Tomsawyer is on a distinguished road
I was communicating with M2 through a PC with Windows XP, But to communicate with the Mazatrol side of the computer I had to purchase software that was able to comunicate with the mazatrol software. However on the EIA/ISO side of the Mazak memory I had to use a different cable and comunicated using a common hyperlink in assecessarys in my personal computer. The doen't drip feed correctly but usually transfers EIA programs correctly.
Newbie- Mazak H-500/40 RS-232 communication question bytecafe Mazak, Mitsubishi, Mazatrol 3 10-20-2010 11:10 AM
Mazak L 32 communication problem breazr Laser Engraving & Cutting Machines 8 06-18-2010 01:40 PM
mazak communication trouble speedrider General Metal Working Machines 2 04-19-2009 06:40 AM
Communication Problems dillweed General CNC (Mill and Lathe) Control Software (NC) 1 10-18-2006 10:12 AM
Fadal Communication problems sc_crasher Fadal 9 03-14-2006 11:38 AM
