Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol
Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here!
Old 01-12-2012, 01:46 PM
Bada Bing is on a distinguished road
Mighty Comet 1500
Hi Guys,
A little help here, my tool carousel is stuck under the spindle, cant get any thing to move on a tool change?, any suggestions?? meldas control what is the m-code to return carousel home????
Old 01-23-2012, 11:39 AM
camsys is on a distinguished road
The tool change arm and any other M-code are passed to the PLC.
The PLC logic is programmed by the OEM (Mighty in this case)
Other than an M06 there's no m-code that maneuvers the ATC in
segments.
Hopefully you have a maintenance manual for the machine. What
needs to happen is that the ATC needs to be realigned to its
standby position. This is usually done at the top of the ATC, where
a clutch is disengaged and the arm rotated manually.
Is your machine throwing an Alarm code? My guess is that it
would be, and the alarm would say something like the ATC not in
position.
You can contact Mighty (they're on the WEST COAST) and probaly get
a maintenance manual that shows how to recover from a missed tool change.
Old 01-23-2012, 09:14 PM
thanks camsys
Need Help!- Mighty Comet vmc500-p Gpl625 General Metalwork Discussion 2 04-12-2012 02:01 AM
Need Help!- Setting up Mighty Comet 1000 VMC rogerindigo Mazak, Mitsubishi, Mazatrol 1 04-27-2011 01:25 AM
Problem- MIGHTY COMET MIDAS 320 CONTROLL joshuasalens Machine Problems, Solutions , Wireless DNC, serial port 3 07-29-2009 07:18 PM
Need Help!- Mighty Comet with Meldas M0 Bert10 General Metal Working Machines 0 08-02-2008 05:35 PM
Need Help!- Mighty Comet/Viper 1000 - communication czech CNC Machining Centers 0 03-26-2008 04:40 PM
