Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol
Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here!
Old 01-10-2012, 07:35 PM
andra's Avatar
andra is on a distinguished road
MRj2-100-CT Turret Unit
Dear all,
mazak QT200 all condition ok ( x,z axis and spindle are normal ) except the turret unit can not rotate when give command, on mrj2-100-ct unit led show B1, as far as i know when normal condition must have C1 code on unit. tq
Old 01-17-2012, 02:43 PM
gbezzegi is on a distinguished road
Originally Posted by andra View Post
Dear all,
Hi Andra,
are you sure it is B1? Not 61?
If 61 it means reference point return unfinished.
What about backup battery?
You should run Mitsubishi software and check Alarm Display screen.
Tell me actual alarm please.
Bye, Gabor
Old 02-06-2012, 12:50 AM
andra's Avatar
Dear gbezzegi,
sorry for late reply, on unit show b1 not 61. On mr-j2 setup software not have alarm.
Old 02-06-2012, 03:22 AM
Dear Andra,
may I ask you to take a picture about your drive please?
In my manual there is no alarm B1.
Thank you!
Gabor
Dear gbezzegi,
Old 02-17-2012, 09:17 PM
andra's Avatar
dear Gabor,
following the instruction manual, this condition not indicate have alarm, but have incomplete initialization when start up, something like waiting some signal for make the unit in ready status, i look on diagnosis monitor on mr-j2 setup software SA & RDY output signal is turn off, i try to replace with other unit still same.
ID:	153027   Click image for larger version
ID:	153028   Click image for larger version
Configuring steps/unit.....what unit? HereinCS Mach Software (ArtSoft software) 2 03-07-2011 07:57 PM
Need Help!- FANUC 15-MA Battery unit & I/O unit etc gbowne1 Fanuc 0 05-04-2010 08:47 PM
Tool Turret Fault Alarm on TL-1 with no Turret? Edster Haas Lathes 10 02-08-2010 08:35 AM
MRj2-ct setup software terra103 Mazak, Mitsubishi, Mazatrol 3 03-17-2008 02:47 PM
