| Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here! |
1990 Mazak m4 I am trying to turn a very large diameter part on my m4. I cannot get the geared head to stay in first or second gear. I can change it from 3 to 2 or 1 in manual mode but as soon as I try to run in auto mode it changes back to 3. This part is 13" in diameter so i really need low gear. I tried an m code to shift into a low gear in the program but it still goes back to 3 before starting the spindle. I also tried a manual program if that makes any sense, where it allows you to select the gear but when i hit cycle start in auto, no matter what It shifts back to third gear. I also set the max rpm for the program down to 200 with same result. Please help. I find nothing in the manuals and mazak tech. support told me to unplug the solenoid to keep it in low gear, there has to be a simple solution to this. Again Please Help. |
| I know that for both M500 and M700, it is the slimit1,2,3,4 and smax1,2,3,4 params in your spindle parameters. Check the spindle parameter menu (not the SP###, the other spindle parameter menu). Cheers. Last edited by botha.y; 01-09-2012 at 03:05 PM. |
| Problem- Mazak QT20 Gear change to 1 produces spindle to stop and go | daveh06033 | Mazak, Mitsubishi, Mazatrol | 9 | 09-28-2011 02:54 PM |
| Need Help!- 1990 Mazak LaserPath Turbo-X48 | Mykal Ward | Laser Engraving & Cutting Machines | 4 | 04-22-2011 09:31 PM |
| Build Thread- Gear change pgm? How to handle | tubeguy | General Metal Working Machines | 0 | 02-19-2011 07:37 PM |
| Need Help!- Having trouble with vf2 gear change | Kenneth434 | Haas Mills | 0 | 10-12-2009 09:21 PM |
| Change gear set up for threading | Turn4fun | Mini Lathe | 1 | 11-04-2008 07:19 AM |
