Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol
Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here!
Old 01-04-2012, 04:35 PM
underthetire is on a distinguished road
Nexus 400Y help
So our Y axis on the NExus is off by .0025". Called Mazak, got an automated message saying the line is no longer monitored?? Anyone know how to re-set the Y axis 0 position on these controls? Fusion control BTW.
Thanks a bunch.
Old 01-06-2012, 08:46 PM
tds11223 is on a distinguished road
Yes, it is a parameter, but be careful the X value will also need to be adjusted.
Old 02-15-2012, 03:37 AM
Robbo1710 is on a distinguished road
I think the parameter is M16, alter the Yaxis by the error then home the Y axis. then clock a tool station (if it is further out alter the other way then re home and check again). The Xaxis will have moved alter this (probably half the error) then home it and recheck. Hope this helps.
Problem- Mazak Quick Turn Nexus 200 lathe with Mazatrol 640 T-Nexus control arwinder Mazak, Mitsubishi, Mazatrol 4 01-10-2012 08:31 AM
Problem- Mazak Integrex 400y Bobcau Post Processor Files 1 10-11-2009 06:41 AM
Need Help!- post processor Integrex 400y Bobcau Mazak, Mitsubishi, Mazatrol 0 05-20-2009 11:44 AM
Need Help!- VMC MAZAC V NEXUS 410 B fenix728 Mazak, Mitsubishi, Mazatrol 1 04-04-2009 09:34 AM
Mazatrol Cam T-2 to 640 T Nexus HarleyRyder CNCzone Club House 0 08-26-2005 08:43 PM
