Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol
Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here!
Old 12-18-2011, 01:09 AM
nybuxt is on a distinguished road
G32 Threading on Mazak Slant 15 Funuc 6T
I am trying to thread up to a shoulder (feeding right to left)on a part and used a G32 threading cycle. Everything worked just fine until I realized it's a left hand thread. The programming manual examples use M3 to run the spindle but I can only use a left hand holder in the turret, which requires me to run an M4 code.....which is causing the problem. I understand I can use a left hand threading bar running the M4 code and I will get right hand threads.
My question is: Is there a way to use the G32 cycle , using M4, and feed left to right from the shoulder ?
Thank you
Old 12-18-2011, 11:38 PM
Theading to a shoulder g32 Mazak slant 15
To answer my own question.....turns out Kennametal makes a drop neck right hand holder which allows me to do my threading using a M3 code.
MAZAK SLANT TURN-28 CHANDRU Mazak, Mitsubishi, Mazatrol 4 04-09-2010 04:45 AM
Mazak quick slant 20 cadcamsolutions Mazak, Mitsubishi, Mazatrol 0 09-11-2009 02:24 PM
Need Help!- MAZAK SLANT 15 MPIMOTORS Controller & Computer Solutions 0 07-14-2008 05:57 AM
Mazak Slant 80 with T2 LTS Mazak, Mitsubishi, Mazatrol 4 02-21-2008 08:38 AM
