Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol
Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here!
Old 12-08-2011, 04:03 PM
kendo is on a distinguished road
EIA sub called from Mazatrol: Offset does not apply
The active WPC remains in effect within the EIA sub, but any current offset units do not. Is there a parameter perhaps that will change this?
Old 12-08-2011, 04:10 PM
Old 12-13-2011, 01:39 PM
bildoo is on a distinguished road
Parameter
Parameter F
70 needs to be a 1. This will allow the offest to carry to an eia program.
Old 12-13-2011, 03:09 PM
hmmm, F70 talks about multiple machining and # of repetitions... I would have never guessed that one. Thanks, I'll check it out in the morning.
Old 12-20-2011, 02:35 PM
thank you bildoo, works perfect
too bad the manual gave no inkling that that parameter would have the desired effect
Apply a knurl to a surface Get lucky Solidworks 3 09-12-2011 06:10 PM
Would You Apply for a CNC Job if the salary was described as competitive? CNCJobs.Org.UK Polls 2 03-22-2011 03:53 AM
Need Help!- Mach3 wont apply offset? lpmfg Mach Software (ArtSoft software) 1 11-29-2010 08:36 PM
Need Help!- Macro for FIXTURE OFFSET (mazak variaxis mazatrol matrix) NCexplorer Mazak, Mitsubishi, Mazatrol 5 05-26-2010 10:19 AM
How Do You Apply Cutter Compensation ? jonbanquer BobCad-Cam 10 01-28-2006 09:19 AM
