Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol
Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here!
Old 10-20-2005, 02:51 AM
BeanO's Avatar
BeanO is on a distinguished road
Mazatrol subprogram
I'm running a mazak integrex (1999) turning center,(4axis lathe,with milling)
I can get a Mazatrol main program to use an ISO subprogram, but I can't get a mazatrol MAIN program to run a mazatrol SUBprogram...
Any help would greatly appreciated...
...Thanks,
PS, I will post the correct controll soon...I think it's an integrex 35..??..
Old 11-02-2005, 04:16 AM
BeanO's Avatar
yup, mazatrol integrex 35Y
Old 11-02-2005, 12:07 PM
psychomill is on a distinguished road
Integrex 35Y is the machine, ... the control would be Fusion 640 or Mazatrol something. It should say on the monitor bezel.
The sub should work. I don't think this is a parameter issue, not for going Mazatrol to Mazatrol anyway. You do have a sub created for the sub number you're calling for right? What alarm, if any, do you get?
It's just a part..... cutter still goes round and round....
Old 11-17-2005, 07:54 AM
r-sport is on a distinguished road
In the end of the main program make an "end" sequence
there you have 6 selections
"counter " "return" "WK No" " cont" "NUM" "shift"
punsh in the name for the sub program no under "WK No"
select 1 under the counter select 1 under return and 1 under cont
an do the same in your sub program only put in your Main program no under WK No
I hope this vil help you!
It works on an integrex 200sy with an 640Mt
Old 11-17-2005, 07:55 AM
...Thanks,
Old 11-24-2005, 04:12 AM
BeanO's Avatar
Thanks for the help!
I haven't had a chance to try it out (too far behind at work), But I WILL try it out as soon as possible.
PS.. The soft keys you described are also on my machine, so it should work well, thanx again..
chris
