Results 1 to 3 of 3
Thread: clock setting parameter
    Mar 2011
    Does anyone know the parameter to set the clock on a Mazatrol T+?
    Thanks in advance
    Jul 2007
    Put the machine in HOME mode and push the EMG stop button. Press and hold RESET and then press the down arrow key. You should see a cursor on the time blinking. Input the year as YY.MM.DD and INPUT then the time as HH.MM.SS and INPUT.
    Mar 2011
    Smile
    Thanks, worked fine!
  1. Parameter setting of Fanuc 18i
    By alexium2007 in forum Fanuc
    Last Post: 04-08-2010, 01:37 PM
  2. Need Help!- Help with setting a parameter.
    By matt_773 in forum Milltronics
    Last Post: 10-05-2009, 11:17 PM
  3. CAPPS Parameter Setting?
    By xenginebuilder in forum Mori lathes
    Last Post: 04-25-2009, 10:37 AM
  4. parameter setting help
    By luis cuellar in forum Haas Mills
    Last Post: 07-18-2008, 12:39 AM
  5. G76 Parameter setting
    By Gorrell in forum Fanuc
    Last Post: 01-29-2007, 03:21 PM
