Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol
Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here!
Old 11-03-2011, 11:38 PM
rjw rjw is offline
rjw is on a distinguished road
Need help with Mazak VTC-16B tool length/toolchanger
A friend of mine just bought this machine. It has the M Plus control
I've been slowly working out the bugs...but Mazak hasn't been vey helpful and we have no operator's manual for the machine, just for the M-Plus.
I have the machine up and running, but outside of a coolant leak from under the middle of the machine, I have several other questions/problems
1) The tool length measuring device isn't working
2) The toolchanger will not extend manually, but the machine will do a tool change, although I've seen a lot cleaner execution...lol I need to tweak the parameters for Home 2 so thxtend , so that the spindle and carousel aren't smacking each other around.
Can someone describe the correct procedure to get the toolcahnger to extend, so that I can load the carousel (after fixing all the broken springs amd damaged alignment plates.
Also, the correct procedure to check tool lengths?
I'm trying to figure out if the problem is with me or the machine....(probably a bit of both!!)
thx
Old 11-04-2011, 06:53 AM
rjw rjw is offline
1 of 2 problems solved
Ok...quick update
Mazak told me that in order to get the toolchanger to extend/retract manually using soft keys, that the machine needed to be at home 2 (toolchange position) and then to jog the z axis out of the way.
That didn'tork, but what did is to move the Y axis back to home 1
So the problem was between the seat and the steering wheel...
ANy thoughts on how to get the measuring device working?
thx
Old 11-05-2011, 12:26 AM
rjw rjw is offline
Problems fixed
Message to self...problems resolved
Old 11-05-2011, 12:28 AM
rjw rjw is offline
Never mind...I fixed it
Need Help!- set up tool length offset and ref tool on mill buklattt CNC Machining Centers 2 04-01-2012 11:01 AM
Need Help!- Mazak tool length measuring unit door dcapik Mazak, Mitsubishi, Mazatrol 2 10-22-2011 11:24 AM
Tool changer for TM-1 , made yourself a toolchanger pit202 Haas Mills 11 11-04-2010 09:25 AM
G43.1 - Tool Axis Direction Tool Length Compensatioin EngTech Mazak, Mitsubishi, Mazatrol 8 12-06-2007 04:01 AM
