Hi
I am running Mazak AJV18 with mazatrol M32 control. while running the machine the system disk (3.5" Floppy) is scratched and now I can not run the machine. Whenever I turn on the machine, it goes to alarm. Following description is written on the Floppy. System No: BND-212W001-C1
Does someone has a same floppy or is there any way to recover or copy the data from my scratched disk.
I beleive the disk is in a special format that cannot be coppied with a regular PC. You will have to get a copy through Mazak or Mitsubishi.
