It is possible to set the tool offsets to inlude a wear column.
If you go to www. meau. com then downloads, you can
get the M520 instruction manual. You will see what's referred to
as "TOOL OFFSET MEMORY TYPE II"
You will need to change a machine parameter that's outlined in the
instruction manual.
LinkBack URL
About LinkBacks
