Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol
Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here!
Old 10-19-2011, 11:56 PM
littlerob's Avatar
littlerob is on a distinguished road
Mazak G-code
Quick question:
We have a Nexus MSY, the current operator uses the Mazatrol to program, I want to use MasterCam, but don't have an example of the G-code format to start building a post. Is the formating the same as Fanuc?
Thanks, Robert
The beaten path, is exclusively for beaten men.
Old 10-20-2011, 12:05 AM
txcncman is on a distinguished road
Here's a start:
Post Processors for Mastercam
http://www.cadfamily.com/download/CA...torial%201.pdf
http://www.kirkcon.com/
Old 10-20-2011, 12:32 AM
Maybe this?
EIA programming examples - Practical Machinist - Largest Manufacturing Technology Forum on the Web
Old 10-20-2011, 12:35 AM
Or this?
http://www.cnczone.com/forums/mazak_...ogram_eia.html
Old 10-20-2011, 12:53 AM
littlerob's Avatar
Thanks, though that is Mill code, but it looks pretty standard hopefully it will be the same case for a turning center.
Robert
Old 10-20-2011, 01:01 AM
From what I remember of G-coding Mazak lathes over 10 years ago, you can probably just use a default Fanuc post to get started. Where you might run into problems is some of the M-codes and canned cycles. If you keep everything G0, G1, G2, G3, I, K, etc. basics, then it should work. You might have to toy with some of the formatting at some point.
Old 10-20-2011, 01:58 AM
littlerob's Avatar
Thanks, I don't have any problem mofifying a generic Fanuc post processor (try it for an Okuma ), I just needed to know if I could refrence Fanuc for where to get started.
Robert
MAZAK 250 MSY eia code example stinkfist General Metal Working Machines 0 08-14-2011 12:48 AM
Need Help!- Mazak QT10 T2 Code 22 newbi100 Mazak, Mitsubishi, Mazatrol 1 06-30-2010 08:28 AM
Mazak tapping G-Code MadPickinSkills G-Code Programing 2 03-28-2008 08:43 PM
Help with mazak g-code dgchumley Mazak, Mitsubishi, Mazatrol 3 05-02-2007 03:32 PM
g code mazak robs_96 Mazak, Mitsubishi, Mazatrol 8 10-16-2006 02:17 PM
