Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol
Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here!
Old 10-18-2011, 08:35 PM
Castle1 is on a distinguished road
Mazatrol not allowing taper thread
A small taper .014 or less in 2.8 inches still threads straight. I have X start at .435 and X final point of .440 (to help counter flex in part) z of 2.8. I have tried a steeper taper like .04 per side and It will do that, but the smaller tapers it will not. The numbers in the Position screen stay at same X value, the entire length in Z. It is a T Plus control on a QT 15N lathe.
Anyone else know why this might be? It will cut a .005 (intentionally programmed) taper on a Bar Out OD turn, Just not with Thread Out.
Tags
taper threads, threading problems
taper thread on okuma... WERNER123 Okuma 11 10-10-2011 05:21 PM
Need Help!- NPT Taper-to-Straight-to-NPT-Taper Thread bdyenter General Metalwork Discussion 2 09-16-2009 08:10 AM
Need Help!- Thread Milling a Taper automizer G-Code Programing 19 06-12-2008 10:23 PM
Newbie- taper thread cutting cncmc Mazak, Mitsubishi, Mazatrol 4 05-05-2008 04:59 AM
taper thread gcrandall Mazak, Mitsubishi, Mazatrol 4 05-17-2006 10:13 AM
