Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol
Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here!
Old 10-18-2011, 12:08 PM
eltorio is on a distinguished road
SERVO LAG EXCESS Y AXIS (Y axis won't home)
Dear All,
As I wrote in a precedent post I bought a Mazak VQC20/50 controlled by a Mazatrol CAM M-2
My problem:
When I try to home Y, after moving Y+ by impulse, I finish with a message:
"2 ECART TROP IMPORTANT AXE Y" wich can be translate by "2 SERVO LAG EXCESS Y AXIS"
Does anyone have an idea?
Mr Mazak told me that it can be a servo problem and I need a mitsubishi tech but I spend two much money in this tool...
I hope there is a solution because I saw this machine working.
Last edited by eltorio; 10-19-2011 at 10:37 AM. Reason: Correct trantlation / change to solved
Old 10-19-2011, 03:56 AM
With Eliseo's help (he send me the complete CAM M2 operator manual),
I find the english message equivalent to french "ecart trop important axe Y"
The english error is "SERVO LAG EXCESS Y AXIS"
Thank you
Old 10-19-2011, 04:26 AM
EliseoMonteverd's Avatar
EliseoMonteverd is on a distinguished road
Some time ago, I had the same problem.
Finally I had to replace Z axis encoder and clean position switches.
Old 10-19-2011, 04:47 AM
Thanks again Eliseo,
I'll first try to find the Y axis position switchs, I don't know where are they but I'll investigate this evening.
Old 10-19-2011, 07:10 AM
Thanks... I've found I think the most stupid problem.
After understanding how the "home" process works. I disassemble the Y axis protectors and inspect the screws, the servo, the belt... I move Y axis in direction of the proximity sensor and saw a big screw blocking the travelling!!!!
The carrier forgot to remove it!
Without this screw the Y axis can go near the proximity sensor and now...
Problem- Z-axis home gracemach Fadal 1 05-02-2011 04:48 PM
Need Help!- Z Axis can't find home Doubleddaved Haas Lathes 4 11-22-2010 01:18 PM
Z axis home problem EliseoMonteverd Mazak, Mitsubishi, Mazatrol 23 03-01-2010 08:26 AM
A axis wont home why?? JohnCo Mach Mill 2 11-04-2009 01:52 AM
How do you home an A axis? FandZ DIY-CNC Router Table Machines 6 09-22-2009 07:22 PM
