Results 1 to 5 of 5
Thread: Help needed on 4 start thread
    Registered extanker59's Avatar
    Mar 2008
    We are making a 5/8"-18 4 start OD thread on a Mazak quick turn 100. Material is 17-4PH. Coolant concentration is slightly high at 11%. SFM tried 30-70.
    Made our own shim at 6.4 deg (should be at calculated 6.89 deg).
    Major tearing at front of thread.
    Should the shim angle be closer? Did I do the math wrong?
    Driving me crazy.
    May 2004
    I get 22.8 degrees. Maybe I do not understand what you mean by "shim".
    http://www.kirkcon.com/
    Mar 2008
    On laydown thread holders they have an angled shim (also called anvils) that goes under the insert. You change shims depending on the diameter and TPI.
    For example using the SECO chart 1/4"-28 thread would take a #3 shim which is 3 degrees. Our part is outside the chart so the calculation, according to them, is arctan lead/(pitch dia x 3.14)
    On our part the lead is a really fast .2222 SECO doesn't sell the proper shim so we had to make our own.
    We tried all the shims we had on hand (up to 4 degrees) but they were much worse.
    Mar 2008
    Just an update/final word.
    Got it to work by increasing the SFM to 100 and grinding more relief on the threading insert.
    Still not convinced we had the right shim angle but we got the parts out the door.
    May 2004
    The relief on the cutting tool was what I was thinking you were getting at. Of course It would significantly weaken the insert, but I guess you made it work.
    1. 5 start thread? a-axis? 8020?
      By NogginBoink in forum DIY CNC Router Table Machines
      Last Post: 12-01-2010, 03:55 PM
    2. Acme thread 1/2-8 (8 start or 2)
      By rmubaja in forum Linear and Rotary Motion
      Last Post: 12-02-2009, 10:14 PM
    3. Newbie- Another newbie, another ?? thread before I start
      By Realmseeker in forum Joes CNC Model 2006
      Last Post: 04-05-2009, 08:40 PM
    4. Multi-start thread?
      By DonutSlayer in forum Daewoo/Doosan
      Last Post: 03-03-2008, 11:07 PM
    5. READ THIS BEFORE YOU START A NEW THREAD!
      By CNCadmin in forum Vendor Discussion
      Last Post: 12-28-2007, 02:49 PM
